If you use the ECU programmed for the auto trans your timing will be advanced 5 degrees when it thinks it's in gear.
If you chip the ECU with a tune for a 5 speed you can just leave the wire disconnected which will make it think it's in gear all the time. This doesn't appear to cause any problems and that's how I have had mine for years.
